Dragon Center 2.0.82.0 Mystic Light will not control the lighting
nxnit90
Dragon utility center on my MPG-X570-GAMING-PRO-CARBON-WIFI MB automatically updates to version 2.0.82.0 and now after updating, Mystic Light will not control the lighting on my DRAM . module, AIO Liquid CPU Cooler, FAN system. Unlike previous versions theres that there is no way to link DRAM, AIO Liquid CPU Cooler, system fan to illumination MB.
    470.1 KB · 檢視: 2
    341.5 KB · 檢視: 1
Dear Sir,
Please help to follow below procedure to verify again.
1. run riagnostictool to uninstall diagoncenter. You can download diagnostictool from the following link,
2.run generate log
3.run uninstall ui & stk
4.download dragoncenter 2.0.82.0
5.install dragoncenter 2.0.82.0
Please help to follow above procedures to verify this issue again, thanks.
nxnit90
I have done like instruction.
But still nothing has changed.
Mystic Light will not control the lighting on my DRAM module, AIO Liquid CPU Cooler, FAN system.
Please. I want new version
Main: X570 Carbon wifi /Corsai RAM/ AIO 360 Cooler Master/ FAN system Cooler Master.
Dear Sir,
I have checked this issue with MSI and it looks that problem might related to the specific memory, can you please let us know what kind of memory did you use? Can you help to take a screenshot of the label on the memory for reference?
nxnit90
Mystic Light will not control the lighting Mainboard and
Cooler Master MasterLiquid ML360R RGB Liquid CPU Cooler
MASTERFAN RGB system
    25.9 KB · 檢視: 0
    33.2 KB · 檢視: 0
    30.6 KB · 檢視: 0
    35.2 KB · 檢視: 0
    34.2 KB · 檢視: 0
    34.6 KB · 檢視: 0
    35.2 KB · 檢視: 0
    41.7 KB · 檢視: 0
I have noted that you`re using cosair memory module, may I know did you install corsair icue RGB app? If you install this app and then you have to enable full software contrl in icue otherwise dragon center is not able to adjust corsair rgb mmeory effect, please help to check it again.icue.PNG
nxnit90
No
I don't install corsair icue RGB app?
I only installed Dragon Center
Dragon Center 2.0.75.0 controls the light
I am updating to 2.0.82.0 and I can't control the light
From version Dragon Center 2.0.80.0, you must install Cosair icue app and enable full software control in icue as I mentioned above otherwise it`s not able to control lighting, thanks for your understanding.
nxnit90
OK ! Thank ad
Feeling about software Dragon Center 2.0.82.0
- trouble
- Not easy
    327.3 KB · 檢視: 2
    508.3 KB · 檢視: 2
    322 KB · 檢視: 2
Any questions, please feel free to post your question here.
